RC Injectors?
Old Oct 28, 2002 | 08:06 AM
XzzYzzX's Avatar
Default RC Injectors?
I have a 91 Crx Si with a 95 gsr in it. I am wondering what kind of injectors should i go with because my stock crx ones are leaking so i need new ones? I need to get the crx ones cause gsr injectors don't fit the harness.What else should i do?
Old Oct 28, 2002 | 08:31 AM
badCRX's Avatar
New User
Default Re: RC Injectors? (XzzYzzX)
The flow rates of the B series motors are 240cc. Just tell them you need it for that type of car. I believe its the Peak and Hold style. You might want to get a little higher if you are planning boost. You might find someone on here for some stock ones for cheaper though.
Old Oct 29, 2002 | 11:33 AM
joncivLS's Avatar
you can use 91 ls injectors
Old Oct 29, 2002 | 12:25 PM
Tuan's Avatar
Default Re: RC Injectors? (joncivLS)
Where are they leaking from? It just may be your top o-rings. From what i understand, that all B and D series injectors have th same flow rate 240cc but the differences are in the clips, and peak hold, or staruated, which you need is the peak and hold.
That's my 2 cents
Adi_King
Jun 29, 2015 08:02 AM
Dave2094
Jul 13, 2008 08:17 AM
r30slick
Jan 10, 2002 10:02 AM
