radiator problem.
Old Sep 14, 2006 | 04:29 PM
Wannabe JDM's Avatar
Default radiator problem.
I just finished putting in my JDM ITR swap into my 99 GSR.
However, Im running into a little problem. I Turn on the car and let it warm up but the fan never turns on. the fan is hooked up and all.
i took it around the block to see waht it does. temp stayed normal but steam started coming out of the hood. steam was forcing its way from under the cap.
could it be the thermostat? i have a mugen thermostat and fan switch.
Old Sep 14, 2006 | 05:27 PM
anybody?
Old Sep 17, 2006 | 05:27 PM
crxcel's Avatar
Default Re: (slowej)
sounds like you have an air lock.. Not sure if your motor is same as the GSR but i was having same problem so i took hose off of head spout. The little hose that goes to the throttle body that is. Then I filled it up with antifreeze through the normal rad cap until it started to come out of the hose that goes to the throttlebody. Worked awesome. Took it around block and then topped it up.
jeremyrocksursox
Oct 20, 2009 05:54 AM
MFButler
Aug 12, 2009 07:40 AM
vlude99
Jul 30, 2009 05:58 PM
yellowmonkeyboy
Aug 22, 2003 11:31 PM
