rad hoses
i have a 2001 b18c1 in a 93 del sol and i have had the integra rad in it and now im turboing and went to the stock del sol rad......i am wondering what rad hoses will work....i need the upper and lower.......if anyone could help that wounld be great thanks
The GSR hoses should work. If the radiator has a smaller diameter inlet/outlet than the hose diameter, cut a small piece off your stock civic hoses and put them on the inlet/outlet and then put the GSR hoses on over top of that. It can get tight, so you might have to use some silicon spray so get the hoses to slide easier.
Dead CIVIC
Jan 28, 2012 09:07 PM
ForgetMyNameX07
Nov 7, 2008 06:29 AM
Mr. JDM-GSR
Feb 9, 2006 05:30 AM
delsolrob
10
Apr 27, 2004 08:57 PM
