Putting VTEC head on b20z
You have to wire up Vtec if it in not wired up
Yes A b20z dizzy will work on a vtec head but you have to cut the leg closest to the vtec solenoid for it to fit and rewire it if you are running it with a obd one harness
The car is already running obd1 with the b20. So it just needs the leg cutoff and the vtec pressure switch and the vtec solenoid need wired?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy »</TD></TR><TR><TD CLASS="quote">The car is already running obd1 with the b20. So it just needs the leg cutoff and the vtec pressure switch and the vtec solenoid need wired?</TD></TR></TABLE>
no
you need to reiwre the dizzy for your obd one harness
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy »</TD></TR><TR><TD CLASS="quote">I was still gonna use the b20 distributor that is wired in for obd1. Is that cool?</TD></TR></TABLE>
Yeah i have done it before
HONDA?
15
Jan 5, 2015 07:45 AM
