purchasing a new motor???
Old Jul 5, 2003 | 07:42 PM
EGRhatch's Avatar
Default purchasing a new motor???
in the future im going to be purchasing a used motor, jdm B18C, i was just wondering if before i decide to drop it in what i should do to it, like replacing oil pump, gaskets, etc. im not sure what all i should do, or how much any of the parts would cost. any advice or comments would help out a lot thanks.
-Brandon
Modified by EGRhatch at 9:32 AM 7/6/2003
Old Jul 5, 2003 | 08:40 PM
Nikos's Avatar
Default Re: purchasing a new motor??? (EGRhatch)
new motor? you mean used motor or different motor..
You can search on that......
You can change the timing belt and drop that sucker on there hoping for the best......
Or you can have a gather this stuff to complete the swap and make sure everyhting is going to last for a while
PCV Valve + Grommet (Purolator)
Air Filter (Purolator)
Axles (driver's side and passenger side NEW, GCK brand)
Coolant
Cotter Pins (for ball joint castle nuts)
Distilled water (to mix with coolant)
Water pump + Gasket - OEM
Timing Belt - OEM
Timing belt tensioner - OEM
Spark Plug Wires - OEM
Honda bond (for sealing gasket surfaces)
Distributor Cap - OEM
Distributor Rotor - OEM
3qts Honda MTF
Spark Plugs - OEM NGK-R's
Fuel Filter - OEM
Alternator Belt - OEM
Exhaust Springs/bolts/nuts - OEM
8mm Shift Rod Pin - OEM
Energy Suspension Motor Mount Inserts (not necessary, but prevents torn bushings in future)
Valve + spark plug gaskets (OEM)
Thermostat + Gasket (OEM)
4 qts Oil (Mobil One)
Oil Filter (Mobil One)
Front tranny mount (OEM, was shredded when I pulled the engine)
VTEC Spool Gasket (OEM, taking off VTEC spool to prevent damage from the chains when I hoist the engine)
Exhaust manifold gasket (OEM, head to exhaust manifold upper section)
Exhaust manifold doughnuts (OEM, exhaust manifold upper section to downpipe)
Upper Radiator Hose (OEM)
Lower Radiator Hose (OEM)
3 distributor adjustment bolts (OEM, ones that came with B16A are nearly stripped/missing)
Heater inlet hose(s) (OEM)
Heater outlet hose(s) (OEM)
3/8" coolant lines (Autozone)
Black skinny wire loom (for my various electronics connections)
Tube scrubbing brush (for cleaning exhaust manifold/headers)
Carb cleaner
Scratch pads (brillo pads for cleaning)
Body color paint (to touch up corrosion/rust/nicked paint)
Feeler gauges (for valve adjustment)
Chain or Strap Wrench (for holding the crank pulley)
Pitman arm puller (rented from autozone for balljoint removal)
Dremel tool (for various purposes)
Reinforced cut-off wheels (to cut off pesky axle nuts)
Chisel (for axle nuts)
2X4’s (have many purposes)
Acetone (to clean gasket mating surfaces)
Old Rags (to clean up)
Old Blankets (to protect fenders)
Newspapers/tarp/drop cloth (to soak up spills, and protect garage)
Simple Green (to clean engine and floor)
Fast Orange (Soapless hand cleaner for when your hands are unbearably greasy)
Various ratchet extentions (several 3", 5", 8" and 10" are very helpful)
Deep and Shallow socket set
Torque Wrench
Boxed end wrenches
8mm Pin Punch (to punch out shift rod pin)
3/8" to 1/4" adapter (for torque wrench)
Ratchet extension(s)
Crow Bar (for ball joints, maneuvering engine, prying axles)
32mm Axle Socket
Breaker Bar (to break axle nut loose)
Small Propane Torch (for helping break loose stubborn nuts/bolts)
Spark plug gapper
5/8" spark plug socket
Camera - (for remembering where everything goes)
Labels/Labeled Twist Ties (to label all connections)
Hose (for transmission fluid)
Timing Light
Engine Lift
Engine Hoist Chains
Vacuum Hose
STR Cam Seal
Wire Cutters
Electrical Tape
Soldering Iron and Solder
Old Jul 6, 2003 | 12:29 AM
EGRhatch's Avatar
well i ment new as in new into my car.. but ill edit that anyways...
Old Jul 6, 2003 | 12:38 AM
EGRhatch's Avatar
Default Re: (EGRhatch)
but thanks for the help anyways ... the list will come in handy...
Old Jul 6, 2003 | 06:07 AM
7thGear's Avatar
i think that list should be made a sticky and other things added on.
Old Jul 6, 2003 | 06:30 AM
Nikos's Avatar
Default Re: (7thGear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7thGear &raquo;</TD></TR><TR><TD CLASS="quote">i think that list should be made a sticky and other things added on. </TD></TR></TABLE>
list was taken from https://honda-tech.com/zerothread?id=131949
VTECROAR96typeR
Jun 1, 2009 12:07 AM
Mr.Luder
Mar 15, 2007 03:38 AM
JDM_EK_JOE
May 16, 2006 11:32 AM
hondaracing1
Mar 31, 2004 08:44 AM
