problem with tps need a little help?
Old Aug 30, 2006 | 03:19 PM
Manny86's Avatar
Default problem with tps need a little help?
i have a z6 motor in my rex and the idle is going up and down its drivng me crazy /
Old Sep 1, 2006 | 07:53 PM
mrlegoman's Avatar
Default Re: problem with tps need a little help? (Manny86)
Check for a vacuum leak.
That's all I got.
Old Sep 3, 2006 | 09:27 AM
JasonST's Avatar
Default Re: problem with tps need a little help? (mrlegoman)
Check and bleed radiator fluid. U can check ur tps if u want to. Just backprobe the middle wire on the tps or at the ecu,( signal wire) make sure it's .45V at idle. ALso try cleaning ur iacv.
drzfamas718
20
May 5, 2011 06:48 PM
PhilMac
Jan 14, 2008 11:35 AM
crxfreak1117
Sep 8, 2007 07:05 PM
zseeanz
Jan 14, 2005 06:55 PM
Civic2Fast
Jun 5, 2004 05:55 PM
