Problem with tach
Old Apr 18, 2005 | 12:41 PM
Spins's Avatar
Default Problem with tach
95 hatch with b18c swap.
Problem with tach is at idle the tach sets at zero. When I rev or drive the tach moves but is incorrect. The engine used to rev to 8300rpm now the tach shows around 8000rpm when the limiter kicks in. I'm sure the engine is reving to the correct rpm just the tach is off. I started noticing the tach would read low at idle sometimes. Now at idle it sets at zero. I removed the distributor cap, everything looks clean. I replaced the dist. rotor and plug wires. They where old and showing signs of wear. This didn't help. I unplugged the 2 wire harnesses located behind the distributor they look clean. I sprays some WD-40 in the harness. No difference. Any ideas? I did search.
Rotten Egg
Aug 24, 2009 10:20 PM
hondacivic90zc
12
Jul 3, 2009 08:57 AM
lexusgui
Jul 27, 2008 07:54 PM
Spins
Apr 18, 2005 02:01 PM
vinuneuro
Mar 28, 2005 11:41 PM
