power steering pump problems
Old Feb 24, 2005 | 06:22 PM
WildMan541's Avatar
Default power steering pump problems
I'm having issues installing my power steering pump on my ls/vtec in a '92 si hb. I have the correct mounts to use the gsr pump but the hose fitting that bolts to the pump is too small and does not bolt up. Any easy known solutions? Thanks
Old Feb 25, 2005 | 05:55 AM
civichbdx's Avatar
Default Re: power steering pump problems (WildMan541)
i had the same problem when i did my swap the civic hose wouldnt bolt up to the gsr pump even though everbody said its suposed to but anyway the way i went around it was picked up a hose at my local junk yard off a 2000 gsr the only diffrence is it curves different at the end by the p/s rack youll see what i mean but im sure youll be able to make it fit mine works fine or option 2 no p/s like eveybody else with tell you "youll make more hp" good luck
Old Feb 25, 2005 | 12:29 PM
WildMan541's Avatar
Default Re: power steering pump problems (civichbdx)
thanx, that's wut i figured i'd have to do
OBDII Integra
Dec 3, 2009 07:20 AM
import-tooner
Apr 30, 2009 04:09 PM
Jabinya
Nov 23, 2006 08:06 AM
nutsack
Feb 1, 2002 10:22 PM
