which power steering pump do i need?
Old Apr 13, 2004 | 08:44 PM
meanEG's Avatar
Default which power steering pump do i need?
i am putting a 94 gsr complete obd1 swap ina 99 ex. power steering pump and pressure hose are different. the 99 pump has a larger hole and stright accross the bolt holes. the 94 gsr pump has a slightly smaller hole and it is slightly offset fromt he bolt holes. do i need a 99 si pump 94 pressure hose?
thansk alot fella's
Old Apr 14, 2004 | 04:41 AM
tiresmoke's Avatar
Default Re: which power steering pump do i need? (meanEG)
bump I am looking for the same info 94 GSR swap into a 93 integra RS. It sounds as though we have the same problem with the bolt patterns on the pump and hose. Do we need the GSR pressure hose??
Old Apr 14, 2004 | 03:55 PM
delsolsir2's Avatar
just change the line to a obd1 style that suits the angle you need. all the obd2 cars have a larger hole than the obd1. oy you can take your hose and the hose you need and drop it off at a hydraulics hose making store and have one made. but if you are taking it off to have one made you might as well just change it to the one you need
JosB7
Mar 29, 2016 07:26 AM
Jabinya
Nov 23, 2006 08:06 AM
WildMan541
Feb 25, 2005 12:29 PM
rig9896
Aug 11, 2003 02:07 AM
nutsack
Feb 1, 2002 10:22 PM
