Please post your high compression fuel setups???
Old Apr 25, 2003 | 06:02 PM
JDM EG2's Avatar
Default Please post your high compression fuel setups???
I am curious to see what everyone is using for fuel delivery. Please also post your compression and other relevant mods done to motor.
Old Apr 26, 2003 | 03:22 AM
Westrock2000's Avatar
Default Re: Please post your high compression fuel setups??? (TurboB16Coupe)
12:1 B20B Non-VTEC.
BBK Fuel Pump
LS injectors
B&M FPR
The car actually ran really lean, so I disconected the map sensor and sent it into retard mode so that it just dumps a butt load of fuel in there. Now it hovers right around stoich. This has not been the best of luck swap. I had it up to 55 psi and it was still running lean. I'm sure it's something stupid, thats gonna **** me off when I discover it. I just replaced the fuel pump thinking it was that and it wasn't.
Shoulda turbo'ed that b18b!
Old Apr 26, 2003 | 06:35 PM
JDM EG2's Avatar
Default Re: Please post your high compression fuel setups??? (Westrock2000)
Get it dynoed. I just got mine done today and my a/f gauge would always be on lean(red only) when @ WOT. The dynoed a/f ratio showed diff I was running to rich @ 48 psi with stock fuel pump and even @ 40 psi I was still runnig a little to rich on the dyno. My a/f gauge still showed lean though.
So I suggest dyno it and see what is really happening.
Old Apr 26, 2003 | 11:18 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Get it dynoed. I just got mine done today and my a/f gauge would always be on lean(red only) when @ WOT. The dynoed a/f ratio showed diff I was running to rich @ 48 psi with stock fuel pump and even @ 40 psi I was still runnig a little to rich on the dyno. My a/f gauge still showed lean though.
So I suggest dyno it and see what is really happening.</TD></TR></TABLE>
what did it put to the wheels? where did you dyno it?
Old Apr 26, 2003 | 11:20 PM
smokey2.0's Avatar
Default Re: Please post your high compression fuel setups??? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
what did it put to the wheels? where did you dyno it?</TD></TR></TABLE>
never mind, i just swa your post on the #s!
s032105k
11
Apr 14, 2011 08:01 PM
Tchleung
Feb 27, 2005 07:52 PM
hotinteggy
Oct 15, 2004 07:10 AM
tt281gt
Mar 17, 2004 04:22 PM
