p73A0 pistons into LSvtec question
Old Jul 1, 2011 | 01:09 PM
delorean's Avatar
Default p73A0 pistons into LSvtec question
hey guys, I already have my rods shaved 1mm bothsides to get the pistons onto the actual rods so thats not the question...
my question is about the piston/valve clearance.
b18b1 block b16a head Stock LS rods RS machine p73-A0 pistons.
My machine shop has called me a couple times now asking if I was sure that the piston clearance is proper as the dome is a lot higher than the stock pistons (Yes obviously this should be true due to wanting higher comp). in theory as I research more and more it should work, but I would like a definitive answer as to if I will bend my valves or not, or if this is usually (I assume the machine shop I took it to has never done a hybrid - but they are a more reputable shop in my city).
The block face was resurfaced but nothing to drastic was taken off of the block, I have the blackworks LS vtec kit and I think 81?mm headgasket that comes with the kit.
Does anyone know if the pistons will hit? if so what should I do?
rrace002
Oct 7, 2012 09:44 PM
bmorck
Jul 23, 2007 12:04 AM
VSBB6
May 16, 2006 09:09 AM
92eg6lsvtec
Jul 13, 2005 09:42 AM
Triple T
Jan 28, 2003 09:31 AM
