P28 jumper....question
Old Nov 24, 2003 | 04:22 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default P28 jumper....question
ok i have a P28 ECU running my B18C1 with Skunk2 IM and chipped with a J's Racing program....SO the previous owner snipped the jumper to reset the ECU to pass smog which it did. so i want to solderd a new jumper but i didnt notice a difference at all!
it basically gets solderd to te board correct?
this is my first solderd i dont know if its functioning or not since i have no tach to read the Rev Limiter
Old Nov 24, 2003 | 05:37 PM
Newman's Avatar
New User
Default Re: P28 jumper....question (SnoFlake EG)
You solder the jumper in J1 and that basically reroutes the ECU program to be read from the chip in the 27C256 socket location. There are still a couple of other items that need to be added to make it work but otherwise, that's the jist of it.
Old Nov 24, 2003 | 05:39 PM
ejprimo's Avatar
Default Re: P28 jumper....question (Newman)
i cut the j1 jumper on my kenji p28 and it did make a difference b/c vtec engaged at 5000 rpm when i cut the jumper as supposed to 5700 rpm on kenjis chip.
Choy
Engine Management and Tuning
Aug 15, 2009 12:05 PM
user 98292739
Aug 23, 2005 04:42 PM
