P28 with B18B??
i have a 92 si with a p28 ecu, i want to swap in a B18B1 with nonvtec head. What do I need to do? Chip the ecu? Can I run the stock program? and leave the vtec selenoid and pressure sensor wire unplugged? THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot »</TD></TR><TR><TD CLASS="quote">i have a 92 si with a p28 ecu, i want to swap in a B18B1 with nonvtec head. What do I need to do? Chip the ecu? Can I run the stock program? and leave the vtec selenoid and pressure sensor wire unplugged? THANKS</TD></TR></TABLE>
you can have the P28 reprogrammed with a non-vtec (LS) program and it will run on LS specs. No check light as long as everything is wired up correctly.
aberfoyle
Dec 13, 2004 12:37 PM
