oil pressure switch location?
Old Jul 3, 2004 | 07:32 PM
H22T94's Avatar
Default oil pressure switch location?
i was wondering where the oil pressure switch is located on a 92 h22a im trying to see why vtec doesnt work. its in a 94 integra with a p28.
Old Jul 3, 2004 | 08:54 PM
jdmcivicferio's Avatar
Default Re: oil pressure switch location? (H22T94)
the vtec oil pressure swith is right next to the vtec solenoid
Old Jul 4, 2004 | 12:16 AM
Dancing is Forbidden's Avatar
Default Re: oil pressure switch location? (jdmcivicferio)
Id check the Vtec oil first.
Old Jul 4, 2004 | 12:46 PM
H22T94's Avatar
Default Re: oil pressure switch location? (lsvt3c)
what do you mean check vtec oil?
Old Jul 4, 2004 | 09:21 PM
You have never checked your vtec oil dude? Id be worried hardcore, if I were you.
Old Jul 4, 2004 | 10:22 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">the vtec oil pressure swith is right next to the vtec solenoid</TD></TR></TABLE>
This man is right.
vtec oil
Old Jul 5, 2004 | 12:49 PM
integr8er's Avatar
Default Re: oil pressure switch location? (turbogixxer)
changed mine last week
Old Jul 5, 2004 | 09:17 PM
Combustion Contraption's Avatar
you guys are jack asses
Old Jul 25, 2004 | 12:50 AM
adrenaline-racing's Avatar
Did you make sure you were getting 12 volt signal from the ECU to the Vtec solonoid ? Check your oil pressure at the pressure sensor above the jack shaft on the back of the block on the drivers side you can remove the single wire and unscrew the fitting and screw in a pressure gauge.
94wip
12
Jun 20, 2024 07:23 PM
StolenTeg
Oct 8, 2007 02:41 PM
vtecn8ive
22
Aug 3, 2005 01:06 PM
rioninja
Jul 10, 2003 02:55 AM
