Are the obd2b auto wire harness the same as stick?
Old Dec 18, 2004 | 01:38 AM
Mr.DC2TurBo's Avatar
Default Are the obd2b auto wire harness the same as stick?
Ok, I did an auto to manual swap on my 01 LS teg and I am wondering if the wire harness for both stick and auto are the same? Currently I am running my stock 01 automatic ecu and it works fine. But, I was trying to use an obd1 (chip ecu) ecu with a skunk 2 harness (obd2b to obd1) and now after I rev pass 6K rpm it feels like it hit a wall and just doesn't want to go any higher. Are the pins of manual obd2b ecu in the same pin postion as the auto ecu?
Old Dec 18, 2004 | 10:45 AM
Default Re: Are the obd2b auto wire harness the same as stick? (Mr.DC2TurBo)
ttt
Old Dec 18, 2004 | 03:25 PM
smart monkey's Avatar
any check engine lights?
Old Dec 18, 2004 | 08:57 PM
Default Re: Are the obd2b auto wire harness the same as stick? (smart monkey)
only the code of using an auto ecu instead of a stick ecu. but for obd1 ecu no code.
Old Dec 19, 2004 | 05:50 AM
The Clash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">Are the pins of manual obd2b ecu in the same pin postion as the auto ecu?</TD></TR></TABLE>
Yes they are the same.
98savage
May 2, 2007 09:01 PM
TEG777
Jun 2, 2005 07:02 PM
Bleed Black
Feb 13, 2004 10:50 PM
