obd2 to obd1
Old May 19, 2002 | 08:34 PM
twoquickls's Avatar
Default obd2 to obd1
i want to convert my obd2 to obd1...every one says do it but no one as told me the advatages of going to obd1... will it increase hp?i heard it was better for nitrous and turbo true? also what sensors will obd1 eliminate? and i am not sure but is the obd1 ecu like pr3, as in can you read the code the engine is throwing from the ecu? thanx
Old May 20, 2002 | 08:00 AM
Kataku2K3's Avatar
Default Re: obd2 to obd1 (twoquickls)
The PR3 ECU is not OBD 1 it's non OBD. So are you talking about converting say a non OBD CRX to OBD 1? Add a little more and it will probably help out. As for OBD 2 to 1 you will be able to take out the crankshaft speed fluctuation senor and the secondary O2.. Latez
Old May 20, 2002 | 10:32 AM
eg6ajk's Avatar
Default Re: obd2 to obd1 (JDMspecEG6)
there are OBDI PR3 ecus, which were found in 92-3 Integra XSi or RSi (b16a)
they are almost identical to USDM P30 or P61 ECU
Old May 21, 2002 | 08:35 PM
twoquickls's Avatar
i am going obd2 to obd1 i have a 96 ls and i heard obd1 would be better for my since i am running nitrous and i am planning on going turbo soon..i dont realy know the difrences between obd2 and obd1 thanx
RACING INTEGRATION
Oct 12, 2004 11:19 AM
LpBoy2004
Feb 13, 2004 08:25 PM
kool168
Nov 26, 2003 05:13 AM
NeXTLeVeLGeN2
Oct 13, 2002 05:28 PM
