OBD1 engine in OBD2 teg
Im putting a built b18a ls/vtec-t in my OBD2 teg. Currently i have a b18b in the car with a conversion harness to run obd1. My question is what sensors etc are differnt or not on the b18a block that are on the b18b engine? Thanks
Did you build the motor from scratch or did you buy it already built? It should have all the same sensors, but if it was built for an OBD0 car, you'll need to swap the dizzy. If it was built for an OBD1 car, you should be good to go. Might have to change some connectors, I cant remember if the B18a had the 2 prong porceling rad fan switch in the back of the block or if it was a temp switch in the thermo housing.
i built the motor from scratch. so my plan was to take the sensors etc off the obd2 and put them on the obd1 motor. Will this work? any help would be greatly appriciated.
