obd1 Dizzy obd2a harness problems
Old Dec 5, 2005 | 06:17 PM
DirtRider's Avatar
Default obd1 Dizzy obd2a harness problems
Hey guys. done a search.. tryin to figure this thing out.. ive got a JDM b16a gen2 swap in my EK (98) .. im runnin my stock harness right now.. i have a obd2-obd1 jumper for the ecu.. changed injectors bla bla bla.. i need to swap plugs from obd2 to the obd1 plug for my dizzy.. anyone have a wire diagram to swap the dizzy plug? any help would be VERY much appreciated.
thnx in advance...
Ash
Old Dec 5, 2005 | 10:26 PM
Ax3l's Avatar
I'm doing the same thing...
My thread - https://honda-tech.com/zerothread?id=1448353
Old Dec 6, 2005 | 03:21 AM
markturbo's Avatar
Default Re: (Ax3l)
I think this is what you're looking for...
http://img235.imageshack.us/my...g.jpg
Modified by markturbo at 7:21 AM 12/6/2005
Old Dec 6, 2005 | 05:02 AM
Ax3l's Avatar
Default Re: (markturbo)
That link is no good...
Need the whole url...
Old Dec 6, 2005 | 06:32 AM
markturbo's Avatar
Default Re: (Ax3l)
Should work now
Old Dec 6, 2005 | 06:45 AM
DirtRider's Avatar
i actualy found that last night.. its everything i need for my motor(obd1) side of life.. however i think i still need a diff. diagram for obd2a (harness, d16) side.. i tihnk wire codes are dif. b/d 16 are they not..
Old Dec 7, 2005 | 12:28 PM
Katman's Avatar
all you gots to do is color match the wiring from the OBD1 dizzy to your OBD2 dizzy and you should be set.
Also, this there's word that you can completely swap the interals of your OBD2 dizzy into the OBD1 dizzy.....all so you don't have to cut & splice or depin/repin the OBD2 plugs to the OBD1 dizzy.
efrunner09
Sep 20, 2009 10:24 AM
ilsimsli
Sep 26, 2007 01:18 PM
totoshatch
Jun 11, 2007 04:03 AM
pnoyboldstar
Apr 13, 2007 09:13 AM
gezer
Aug 26, 2004 10:42 PM
