OBD0 to OBD1 conversion, where to get conectors?
Hallo,
i plan a OBD0 to OBD1 conversion on my B16A1 CRX.
that i need the o2 sensor, a obd1 distributor and the adapter harness and a obd1 ecu is clear...
but when i install a obd1 distri and o2 sensor to my obd0 harness then the conectors won't fit.
whats better?
- replace the harness conectors to obd1's
- replace the sensor conector to obd0's
and where do i get the conectors from? is there a online shop where i can order them?
Thanks
Malte.
whats better?
Thanks
Malte.
Most of my friends have used Hasport for their swap harnesses, and have been very happy. Good luck
http://www.hasport.com/Products/Wiring.htm
you have to repin the one on the dizzy or make a conversion
cut the plugs off junkyard wire harness
i bought a boomslang obdo to obd1 jumper it has wire for the o2 sensor i had to repin the dizzy no problems
dem0nk1d
Aug 8, 2007 02:17 PM
