obd0 to obd1 ?
Old Jul 10, 2004 | 12:18 PM
dpine's Avatar
Default obd0 to obd1 ?
I have a 90 crx with b series. My question is when converting from obd0 to obd1 I know you need the conversion harness for the ecu and you have to change plugs on the distributor but what about the injectors? Is there any thing else that has to be changes out?
thanks
Old Jul 10, 2004 | 08:59 PM
ESA's Avatar
ESA
Default Re: obd0 to obd1 ? (dpine)
I just finished this swap manually... it's easier than 125.00 for a harness
if you need the info holla....
Old Jul 11, 2004 | 09:34 AM
Colin's Avatar
In regard to injectors you have two options:
1) Use obd0 style injectors, make no modifications.
2) Use obd1 style injectors
-solder on obd1 injector clips (or modify old clips/injectors so they snap together)
-remove injector resistor box
-take the wires that went to the resistor box and solder them all together (or, preferrably use the termination plug which accomplishes this same thing and comes on obd1 vehicles)
I decided to swap to the obd1 style injectors so that I could ditch the resistor box and clean up the engine bay a bit.
Old Jul 12, 2004 | 06:47 PM
IO_303's Avatar
Default Re: obd0 to obd1 ? (ESA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESA &raquo;</TD></TR><TR><TD CLASS="quote">I just finished this swap manually... it's easier than 125.00 for a harness
I could use that info
Old Jul 12, 2004 | 07:29 PM
alleyezonme's Avatar
Default Re: obd0 to obd1 ? (IO_303)
go to http://www.prostreetonline.com and click on the how to section on the far left bar. down a bit they show you how to change from an OBD0 to an OBD 1. they use a crx si w/ a b16. ive never done it b4, i just stumbled across it one time... it might help ya
Old Jul 12, 2004 | 07:46 PM
krazie1's Avatar
BANNED
Default Re: obd0 to obd1 ? (bumpincivic20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumpincivic20 &raquo;</TD></TR><TR><TD CLASS="quote">go to http://www.prostreetonline.com and click on the how to section on the far left bar. down a bit they show you how to change from an OBD0 to an OBD 1. they use a crx si w/ a b16. ive never done it b4, i just stumbled across it one time... it might help ya</TD></TR></TABLE>
doesn't work
Old Jul 14, 2004 | 06:19 PM
dpine's Avatar
PM me I'd like to know. Are there ant DIY on teh web that you know?
surkitroller
Dec 29, 2009 12:58 PM
si 1
Mar 10, 2006 05:23 PM
e jay one
Sep 10, 2005 09:15 AM
91lsteg
May 15, 2005 11:32 AM
rogue3221
Nov 23, 2004 11:36 AM
