NOS HELP!!??!!!
ran a 55 shot of NOS on a zex kit, for my 93 accord with h22 motor. i have msd ignition, pplugs, purge kit, and everything else for it. Problem is, i ran the NOS for the first time, and the heaflights dimmed. Now they wont come back to normal, the lights come on, but there is barely any light coming from them. i checked all the fusees, and relays, and still the same. parking lights work fine, and high beams are fine too. anyone have any ideas??????
Sounds like something went wrong with your wiring, when you hooked the NOS up. Go back over every little thing you did to it. That is if noone has already mentioned this..... hehehehe
The ZEX kit has its own module, its gotta be something either with that, or you burnt up one of your light relays....there are two i think in a accord....check your manual, find your relays and check them....later
Where did you hook up the power for the ZEX at? I went straught to the battery and used 14 gauge wire with a 20 amp fuse.
18 gauge wire will go up in smoke. I know, mine did!
