No o2 sensors, Is that a problem?!?!?!
Old Mar 21, 2006 | 10:26 PM
SpoonEk253's Avatar
Default No o2 sensors, Is that a problem?!?!?!
It just came across my mind that when i decide to go get my car tuned...that i have no o2 sensors? will this effect my engine performance, because i know wideband tuning,you hook it up from the o2 sensor on the headers...but since i got some bootlegged headers, that plug for the o2 sensor is closed shut! what should i do...?!?!?!
Old Mar 22, 2006 | 03:02 PM
JDMC-Kamel's Avatar
Default Re: No o2 sensors, Is that a problem?!?!?! (SpoonEk253)
cut a hole weld in a bung and install a o2 sensor
for wide band cut another hole and weld on another O2 sensor bung
Old Mar 22, 2006 | 06:10 PM
Honda Bull's Avatar
Default Re: No o2 sensors, Is that a problem?!?!?! (JDMC-Kamel)
Yah. You'll most likely want to get an O2... I guess you'll want 2 since you're OBD2. Are you converting to OBD1??? The tuner should be able to disable the engine reading from the O2 sensor for partial throttle if necessary.
aojtin
Jul 9, 2008 01:40 PM
gsrhatchy
Northern California (Sales)
Jul 30, 2005 02:32 PM
speed
Nov 19, 2002 04:28 PM
AfEn808
Jan 21, 2002 05:51 PM
