Need info on B18/B20 swap into EK hatch
ok, I am considering getting an EK hatch, and swapping in a b18/b20...
how much would it cost me to do the following swaps, keep in mind I will do all the labor myself. the poor mans ITR engine B20 regular B18c1 now here is another question... I have heard here and there about "sleeving". Im guessing that it would be possible to get B20 iron sleeves and plop them into a B18, and use B20 pistons (maby just get aftermarket).... is it feasable? How much cash? Im not sure I should do this one on my own, lol. oh, and I plan to do the swap and then between 6 to 12 months later go turbo. I also might be considering direct port nitrous. |
Re: Need info on B18/B20 swap into EK hatch (sinfestboy)
ok, I am considering getting an EK hatch, and swapping in a b18/b20... how much would it cost me to do the following swaps, keep in mind I will do all the labor myself. the poor mans ITR engine B20 regular B18c1 now here is another question... I have heard here and there about "sleeving". Im guessing that it would be possible to get B20 iron sleeves and plop them into a B18, and use B20 pistons (maby just get aftermarket).... is it feasable? How much cash? Im not sure I should do this one on my own, lol. oh, and I plan to do the swap and then between 6 to 12 months later go turbo. I also might be considering direct port nitrous. It is not possible to swap B20 sleeves into a B18. Not only that, but it's unfeasible as well. The engines are the same except for the B20 has one piece sleeves, an 84mm bore and the larger pistons to go with the bigger bore. Everything else is the same including the crank, rods, and even the head. If you did have a B18A/B and wanted it sleeved, Golden Eagle or any reputable shop could enlarge the bore and sleeve the block to the 84mm bore of a stock B20, or even bigger. If you're going turbo, it would be better for you to stick with a non-VTEC engine. I'm not saying VTEC doesn't work well with turbos, but most dyno graphs i've seen have a huge dip when VTEC kicks in. Plus, non-VTEC engines are cheaper from the get-go. Hope I helped. B96v6 |
Re: Need info on B18/B20 swap into EK hatch (B96v6)
ok, sorry about not searching....
but on the topic of vtec vs no vtec... how is there a big drop when vtec comes in? Unless I dont understand how vtec works correctly.... all it does is change timing and go to a diffrent cam profile, right? well could that dip be eradicated with aftermarket, or even custom cams? I just like the idea of being able to have 2 diffrent cam profiles.... |
