Need help with wiring harness.
Old Sep 27, 2002 | 03:12 PM
AB16A2T's Avatar
Default Need help with wiring harness.
I am getting a B18B engine swap into my 1999 Honda Civic EX and was wondering if someone had wiring diagrams of what needed to be done with the harness, I will be using the B18B engine wiring harness and the LS ECU OBDII. Just curious as to what needs to be done. Thank you.
Old Sep 27, 2002 | 11:09 PM
AB16A2T's Avatar
Default Re: Need help with wiring harness. (AresB18BTurbo)
ttt
Old Sep 28, 2002 | 12:01 AM
poison's Avatar
I'd check out http://tech.hybridgarage.com/ as well as c-speedracing.com
For using the harness from the firewall harness to the ECU, you will need to have both the 99 EX pin-outs and color codes of the harness, as well as the LS in order to convert that specific harness (from firewall to the ECU) and knock sensor will need to be added.
good luck
puresteez
Jan 22, 2014 01:28 PM
Maroonda9
Jul 6, 2005 03:52 PM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
gtowni3
Sep 26, 2004 10:05 PM
89JDMcrx
15
Feb 20, 2003 12:42 PM
