Need help: Throwing o2 sensor CEL code!!!
Old May 28, 2002 | 09:09 PM
gsrvx's Avatar
New User
Default Need help: Throwing o2 sensor CEL code!!!
I have a 95 gsr in my 92 hatch and have been throwing a code 1. At the moment, I don't have the space/resources to jack the car up and check under to see if the o2 sensor is disconnected or something. I'd probably be able to do so in 2 weeks. Would it be safe driving the car around meanwhile?
Any tips as to how I should diagnose the prob? Any way to figure out whether it's a faulty sensor or connection? How much $$$ do o2 sensors usually cost? Thanks guys. BTW, I did order a helms manual a couple of days ago cuz I thought it might be a great help.
-Rod
Old May 28, 2002 | 09:35 PM
Kamin's Avatar
Default Re: Need help: Throwing o2 sensor CEL code!!! (RK)
good move with the helms
and well if the o2 sensor is fried, your gas mileage will go straight to ****.
they run from 75$ for a bosch replacment to i think 200 for a honda one.
mine went out during my swap (had to use an impact gun to remove it from stock header, hehehe) im using a bosch replacment, works fine.
Old May 28, 2002 | 10:19 PM
gsrvx's Avatar
New User
Default Re: Need help: Throwing o2 sensor CEL code!!! (KAMiN)
Thanks for the reply man. Yea, I noticed that my gas mileage has suffered a bit. Can I get a bosch replacement @ a local pep boys or something?
-Rod
Old May 29, 2002 | 03:40 AM
EE_Chris's Avatar
I try and stick with OEM parts...so thats what I am going to recommend for you, if yours is indeed bad. However, if you go to the dealer....your a fool. Order from somewhere off the net, like HParts.com. There are tons of places out there to get an O2 for less than 200 bills.
Old May 29, 2002 | 11:58 AM
gsrvx's Avatar
New User
Default Re: Need help: Throwing o2 sensor CEL code!!! (EE_Chris)
I just emailed sohfast.com for more info on the o2 sensors. He's selling for $70..but dunno if it's new/used
-rod
projectEK9
12
Jun 14, 2005 08:05 AM
sackdz
Nov 4, 2003 06:40 PM
spencedogg
13
Oct 28, 2003 06:45 PM
TurboBumblBee
Feb 6, 2002 07:04 AM
