Need help with swap...ASAP!!!
Old Mar 8, 2003 | 03:02 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Need help with swap...ASAP!!!
Well i finally got all the wiring and everything hooked up. When i went to start it it was making a loud thud noise and it turned over but it wouldnt start. I know that were getting gas b/c you can really smell it. It sounds like it has a misfire. I think that i have all the plug wires hooked up correctly...tell me if i do. The bottom left wire on the dizzy(1) goes to the hole closest to the dizzy. The top left(3) goes next...then the top right then the bottom right. Is that right? What else could it be? It sounded weird and it shot fire out of the TB and the header a few times. Is there anyway that i could have my dizzy on backwards? I had to take it out to get it pinned for the wiring and i dont know if i put it back in wrong. Thanks.
Sean
Old Mar 8, 2003 | 03:28 PM
sCeRaXn's Avatar
Default Re: Need help with swap...ASAP!!! (sCeRaXn)
OH yea...Its a 92 LS with the stock dizzy. Im keeping it obd1 by the way. Thanks.
Sean
Old Mar 8, 2003 | 03:42 PM
Kamin's Avatar
i didnt really understand wat you said
but the order is
3 4
1 2
and remember
the cylinders go
4 3 2 1
you did put new plugs in right?
Old Mar 8, 2003 | 03:54 PM
sCeRaXn's Avatar
Default Re: Need help with swap...ASAP!!! (Kamin)
Are you sure that its 4 3 2 1? I was told that its 1 3 4 2. Ill try it your way and get back to you...thanks.
Sean
Old Mar 8, 2003 | 03:55 PM
Kamin's Avatar
the CYLINDERS?
yes its 4 3 2 1
Cyote
Aug 13, 2010 03:26 PM
b_hoov
Dec 1, 2008 08:17 PM
TylerC161
Jan 2, 2007 10:56 PM
MestizoRacer310
Jul 14, 2004 12:31 PM
sCeRaXn
Mar 8, 2003 03:55 PM
