Need help with swap!!!
Old Feb 16, 2003 | 02:22 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Need help with swap!!!
Am i going to have to modify my downpipe to fit my stock exhaust? Im putting a 92 LS into a 90 CRX using HASport mounts. I was thinking that i might have to shorten it to fit with the stock exhaust and cat. If i do have to shorten....are there any other options besides cutting/re-welding? Like some sort of flex pipe pr something? I just dont trust the welders around here...they always have leaks in their work.
I asked this in the EF forum but i didnt get a response...Thanks.
Sean
[Modified by sCeRaXn, 11:22 PM 2/16/2003]
Old Feb 16, 2003 | 02:24 PM
RuffRhyno's Avatar
Default Re: Need help with swap!!! (sCeRaXn)
When I used the stock downpipe from my B18C1 the points to bolt up to the flex pipe aren't aligned. So yeah, I had to custom fabricate it a bit. I cut and welded a nt onto the downpipe that I could slide a bolt through the flexpipe to bolt up, and then welded a stud on the opposite side to be able to put a nut on. Good luck.
[Modified by RuffRhyno, 11:24 PM 2/16/2003]
Old Feb 16, 2003 | 07:23 PM
sCeRaXn's Avatar
Default Re: Need help with swap!!! (RuffRhyno)
Has anyone else had to rework their downpipe somehow? If so then what did you have to do? Thanks
Sean
Old Feb 17, 2003 | 01:17 AM
NirSpec1's Avatar
ya do it all the time Cut and Reweld...
Peace
Old Feb 17, 2003 | 06:30 AM
sCeRaXn's Avatar
Default Re: Need help with swap!!! (NirSpec1)
how much am i gonna have to take off?
Sean
Old Feb 17, 2003 | 03:17 PM
sCeRaXn's Avatar
ttt!!!
waynecoSI
May 15, 2012 04:26 PM
caragan11
10
Dec 19, 2010 11:17 AM
$ISELLTOU4LESS$
Mar 14, 2007 12:08 PM
MysteriousGSR
Feb 3, 2003 07:18 AM
