NEED HELP my 2.2 has big problems
Old Jul 19, 2003 | 06:50 AM
2jdm2's Avatar
Default NEED HELP my 2.2 has big problems
i jus finished installing my h22 in my eg at home but sumthing is wrong
i start up the car and it feels likes its going to die out,oil pressure fluctuates from 20 psi to 60 psi and motor is idleling really rough, i also smell LOTSSSSS of fuel and i have flames and ALOT of black smoke coming out of my exaust and when i go to drive it i put it in 1st i have like no power at all and same with 2nd gear and so on i press the gas but it feels like my car is cutting off any one got any ideas?
the mods i have r:
short ram intake,jdm headers,p13 ecu,fuel pressure regulator,AEM highflow fuel rail,type R fuel Pump and hondata coming in 2 weeks
my car is 93 dx hatch btw
if any one of you have installed a h22 and know step by step how-to installation from dropping in the motor to all the wiring that would be great
tanx
streetracer169@hotmail.com
Old Jul 19, 2003 | 06:56 AM
Turbogixxer's Avatar
Default Re: NEED HELP my 2.2 has big problems (2jdm2)
Whats the fuel PSI at? Is there any CEL(s)? You wire up the resistor box right?
this is for the HCP mounts: http://www.h22hybrid.20m.com/index.html
Old Jul 19, 2003 | 07:01 AM
2jdm2's Avatar
Default Re: NEED HELP my 2.2 has big problems (turbogixxer)
fuel pressure is at 45 psi
when i put my aem regulator on i turn off the car and the pressure drops but if i have my stock regulator fuel pressure stays at 45 psi is that normal?
yep resistor box (i think) is hooked up right
i really need all the wiring steps i think all my wiring is fuked
any help please?
Old Jul 19, 2003 | 07:05 AM
ok, I will send you the wiring diagrams for the resistor box. All the other wire (besides vtec, knock) is just extending. But is there any CEL? (CEL = Check Engine Light)
Old Jul 19, 2003 | 10:16 AM
2jdm2's Avatar
yeah the CEL is on all the time and so does the SRS airbag light it wotn turn off as well
Old Jul 19, 2003 | 10:55 AM
2jdm2's Avatar
if my email streetracer169@hotmail does not work send it to
rowley96@hotmail.com
thanx
Old Jul 20, 2003 | 06:57 AM
2jdm2's Avatar
any help or wiring diagrams?
88 EF Hatch
14
Oct 22, 2009 11:41 PM
88 EF Hatch
Oct 16, 2009 08:54 PM
w00ted
May 8, 2009 07:56 AM
superturboprelude
Jul 10, 2007 06:04 PM
