Need help with h22 civic!!!!PLEASE!!!
Old Apr 25, 2005 | 03:22 AM
civicfanman's Avatar
Default Need help with h22 civic!!!!PLEASE!!!
i just bought a civic with an h22 in it and just had it delivered.
when i went to start it, the motor sounded like it was gonna die, it was so slow starting. also the idle is really weird, it stays at like 2000rpm and to bring it back down all i have to do is pull the gas forward and the idle drops but sometimes it drops too much and stalls.
PLEASE HELP ME WITH THIS< this is my first swapped car
Old Apr 25, 2005 | 03:45 AM
KNIVES's Avatar
congrats on geting your car...but it looks like your in for a treat. there are a number of things that could cause this from the dizy to bad wiring. Are you throwing any codes? If so post them up so others can help you out. Good luck.
Old Apr 25, 2005 | 09:00 AM
Jmunk's Avatar
Sounds like you got someone elses problem.
Old Apr 25, 2005 | 09:13 AM
canis's Avatar
dude what kind of ecu is in it that might be some part of it...
Old Apr 25, 2005 | 07:56 PM
SI_SOLDIER's Avatar
Default Re: Need help with h22 civic!!!!PLEASE!!! (civicfanman)
I had the same problem. Mine would idle high but when I pulled the gas pedal out the idle would start to jump, up and down. I think I messed with the throttle cable and a screw on the throttle body. I noticed that the problem was the screw kept coming loose from the vibration. Worth a check it wont cost you anything.
Rasmusm
Jul 19, 2012 11:11 PM
dek1mfk
Nov 6, 2006 03:25 PM
ge_itr
Sep 17, 2006 08:50 AM
FastSS
Aug 31, 2004 09:20 AM
slow02ss camaro
Jul 31, 2002 09:05 PM
