need help choosing a motor...
i have an 89 crx and i am planning a swap...should i go B18a...or B16a...i am stuck i want the ls because it has more torque...but then i want the B16 for the V-tec...now i know i can get the ls and eventually put a B16a head and have the best of both...i just want to know what everyone thinks...i would also like to know places that can do this around my area...thanks in advance
[Modified by 177ik3, 5:37 AM 8/24/2001]
Go with the LS and get vtec added later. Look at this link on found on another post here,
http://www.jgenginedynamics.com/dynotests5
I would do that, if you really cant decide, then get the B16. If you still want more later, you can add a LS block to that head. When you build a LS/VTEC you ade taking a VTEC swap and putting an LS block on to, all the other engine accessories (i.e. power steering, a/c) has to cater to the head, not the block. Get the B16, you can always upgrade later. If you do do an LS/VTEC later, you can get the LS block, have all the machine work done, then take like a whole day with some friends and swap the blocks, your set for a quick *** car.
id go with a ls motor....im not to fond of b16's....most b16's i think have realy high mileage and i dont trust them.... plus 1.6 liters is to little displacement for me
go with the b16a.i've heard that 4th gen civic/crx's have a clearance problem with the 1.8ltr engines. but that is only what i heard so i'm not sure.that is a good idea to get the b16a and if you want more later get a turbo or ls block (i'm not a big fan of the ls/v-tec)
If u want torque, get a B20Vtec Motor. Its roughly the same size and weight as the B18..u'll have DOHC VTEC power, and displacement for torque.
YUMMMY
YUMMMY
