need help with b16 swap
i just finished dropping in the b16 , I tryed to start it and it cranks over but it won't start.what should i check to figure out what the hell is wrong with this thing .tomorrow i'm gonna check the ignition system to see if it has a spark,the vacum lines to see if i did anything wrong.I checked all my grounds already adn they seem to be fine .if anyone has any ideas please give me your 2 cents it might help.
I would check:
(1) Fuel pump comes on when you turn the key
(2) Fuel pressure (gas in the car?)
(3) Other elecronics work (lights) checking for grounds (all 5)
(4) stupid things- firing order of plugs, harness connections...
Is it throwing codes? My first attempt at starting did not work- I had 4 of the 5 grounds connected. Go figure.
Vacuum lines won't keep it from starting, just idling well.
Sean
Sean
http://hybrid.honda-perf.org/tech/4gtech/eb-4g0.html hope it helps
kc_kc
16
Dec 3, 2010 06:02 AM
91_civicsi
17
Jun 11, 2004 08:26 PM
