need 4g help with the gsr
i have a 94 gsr in a 89 civic si hatch it in and ready to go i just need help with the wiring im using a gsr ecu if its possible if you guys can direct me to a web sight on this if someone has it done thanks alot
Try http://www.hasport.com they have the wiring pinouts for the ecu's. It's gonna be a tough one but with a little work it can be done. You'll need to buy an ecu wiring adapter or make your own since the GS-R ecu won't plug into your harness.
