Mount Identification... Ek H22.
Edit: they are h22 Ek avid mounts pictured...
The previous owner (of the swap) purchased these mounts, and he must be partially retarded because he "doesn't remember the brand name or place of purchase".
They look like typical "avid" mounts, black urethane, and billet aluminum. The motor sits literally 1inch from the firewall, to describe how close it is... I had to remove my fuel regulator w/ bracket from the firewall because my intake arm wouldn't clear it.
Only pictures i have available.
Whatever mounts these are, i am able to use both DA axles with absolutely no binding or shaking problems. I like this quite a bit because i don't have to do the normal route and get hasport or driveshaft shop custom axles.
I was actually wanting to find out the brand name because i wanted to purchase another set but with a higher dur. rating. Like a 70-85a...
i am thinking that too, the motor seems to shift a bit when under high load so i wanted to either get a new set with different durometer, or just replace whatever bushing are in it now. didnt know if i could just call them up and ask them to be replaced though or if i had to get a new set, or just replace the bushings themselves.
http://www.summitracing.com/parts/ENS-16-1111G its something like these go there an ask em for hondas get the mixed one circle an the other one that look like a bit cookie they have it i bought some awhile back
and the ones purchased from there are direct replacment/fitment for the mounts i have? press out and press in with the new?
avids are junk. i have had the worst luck with them. just spend the money on some hasports and do it the right way. i had to move my fuel filter and prop valve on my f swap civic with avids.
This is my daily in the picture and I'm not going to spend money on haspirt. I am running
My lifetime warranty AutoZone axles with the avid mounts perfectly fine.
Yeah I had to disconnect my fuel line also for the filter arm to clear... But it's keep ing my axles from binding and it gave me a few inches of much needed room up front.
I just got done speaking to avid and I'm going to try a 70a and just gotta wait on them to arrive.
ensracer
Jul 11, 2004 09:32 PM
