motor swap
Old Dec 24, 2002 | 08:48 AM
4ghatch's Avatar
Default motor swap
i'm planing on buyin the jdm 1st gen b16 to swap into a 91 dx hatch just wanted to know if i'll need anymore parts to get it running right? So check out the site and see what else i may need that is not on the list. Oh and does anyone know if this motor comes with obd0 or obd1? http://www.osakajdmmotors.com/engines/b16a1.html
Old Dec 25, 2002 | 01:26 PM
pennies_hatchie's Avatar
Default Re: motor swap (4ghatch)
you might want to try the search button if you want more info on this....
but ill help you out as much as i can...
well first off, its obd-0
i believe they only supply you with engine/tranny/ecu/jspec wire harness/mounts
you'll need
1. shift linkages
2. axles
3. water pump/timing belt (optional)
4. other belts (alternator, etc)
5. honda mtf/engine oil
6. spark plugs/wires (optional)
7. other small things (tools)
there maybe a few things i missed, but this is the major ones
Old Dec 25, 2002 | 03:50 PM
4ghatch's Avatar
Default Re: motor swap (pennies_hatchie)
do you know from want car to get axles, linkage if so please help me out
Old Dec 25, 2002 | 06:42 PM
VTECVillain's Avatar
you'll need
1. shift linkages
2. axles
Most important:
8. B Series Mount Kit
9. Injector Resistor Box
10. DPFI to MPFI wiring
The axles, depending on what intermediate shaft comes with the motor would normally be from a 90-93 Integra. The shift linkage can also come from those years but will need modified (cut down and rewelded). Most major mount kit manufacturers sell custom linkage to be used with their kits too. Search this site and you will find the answers to most if not all of your questions. Also check out http://www.hasport.com for more info.
DOHCturbo
Feb 15, 2012 07:14 PM
sbott84
23
Apr 16, 2008 05:12 PM
NIGHT-DEMON
Jun 11, 2007 02:09 PM
jdmeg61
Sep 16, 2006 09:40 AM
90hatchb16
Nov 27, 2004 03:45 PM
