middle layer of head gasket?
Old May 31, 2002 | 10:42 AM
InfamousRS's Avatar
Default middle layer of head gasket?
Iv read and heard that some people only use the middle layer of a OEM head gasket to acheive a higher compression ratio. Is this safe? Will it seal properly?
Also, are GSR and LS head studs the same size and legnth?
Old May 31, 2002 | 10:51 AM
Jaker's Avatar
Default Re: middle layer of head gasket? (InfamousRS)
8 out of the 10 headstuds from an LS can be used for a GSR block B16 head, but 2 of them are too long. As to a GSR head/GSR block, I'm not sure.
Old May 31, 2002 | 02:26 PM
InfamousRS's Avatar
Default Re: middle layer of head gasket? (Jaker)
Anyone on just the middle layer of a OEM head gasket?
Old May 31, 2002 | 03:27 PM
Jackson's Avatar
You'd better hope that the deck and the head are perfectly even if you want to use a one layer headgasket.
NSfit
Sep 20, 2006 06:43 PM
sickerhatch
Apr 16, 2005 10:14 AM
b18prl
Mar 4, 2003 11:17 PM
