Is it me?
Old Apr 11, 2003 | 04:22 PM
2k1_ITR_0736's Avatar
Default Is it me?
I got a 2000 GSR harness, and im puttin my hondata p28 on it. not i look up the gsr harness (ecu) and it says that A1 is injector 4, but on my harness it self, there is no wire in A2 or A2 for that matter. then i look at the 99-00 Si harness diagrams, and it seems more correct. but like the first 4 wires i need to change arent existant in the p28 harness. WTF? evap purge? im sooo lost.
Old Apr 11, 2003 | 05:29 PM
msilbernagel's Avatar
Default Re: Is it me? (2k1_ITR_0736)
Sounds like you need the obd1 pinouts so you know what the connector on the P28 has, and then obd2b (emphasis on the 2B) wiring diagram so you can find the matching signals.
Check out hondada's web site, such as here: http://www.hondata.com/techecuid.html
They sell conversion harnesses to connect your P28 to the 2000 harness..
Mark
Old Apr 11, 2003 | 06:06 PM
Default Re: Is it me? (msilbernagel)
Baahhh, i dont buy **** liek that.
Old Apr 12, 2003 | 11:04 AM
poison's Avatar
First of all bro, be more clear. Doesn't make much sense
You will need OBD1 pin-outs, and re-pin the harness yourself if you choose not to get a conversion harness when hooking up a P28. You will also need OBD1 ECU plugs if you also do not have a jumper harness.
HTH.
Old Apr 12, 2003 | 11:25 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1_ITR_0736 &raquo;</TD></TR><TR><TD CLASS="quote"> im sooo lost.</TD></TR></TABLE>so am i
that made NO SENSE.
dude, proof read.
Nitrozity74
Aug 28, 2017 06:00 AM
hondaacc91
Mar 12, 2010 12:01 AM
germanegturbo
Sep 27, 2008 06:22 PM
essex
Apr 15, 2002 07:37 AM
