Hey, I would like to get feedback on how my thought process is with the ECU and wiring with my LSVTEC build, I hope I am correct.
1992 DX hatch
OBD I b18b1 Wire Harness
OBD I P72 ECU
b18b1 block
2000 OBD II GSR VTEC Head
So, with my harness all I will have to do is add the ryewire for VTEC, no other wiring since I will have the knock sensor taken care of with a tuner, I will also be running a aftermarket intake manifold. For the OBD II head, I will be using a OBD I Distributor from a 1993 GSR, it will bolt right on and have the correct plug outlet for my OBD I harness. For the injectors I will be using the OBD I to OBD II injector adapters. I would appreciate any feedback, thanks in advance.
1992 DX hatch
OBD I P72 ECU
b18b1 block
I think you got it.
