LSVTEC Begining Questions
Old Aug 22, 2004 | 11:29 AM
DAtougeSpecial's Avatar
Default LSVTEC Begining Questions
Lets get right into this. Im using a 97LS B18B in my DA integra right now and ive got enough funds to go LSVTEC. I have located a complete USDM B16a2 Head. Now i have a few questions about piecing everything i need together.
1. What ecu should i use? I am planning to purchase a v-afc to do further tuning but should i get a p28, p30 and what are the differences? and should i be getting it chipped or leave it to the v-afc?
2. Are the ARP head studs recommended or needed to make this swap reliable?
3. Should i stick to a OEM Head gasket or a Cometic head gasket? If Cometic which one should i get because i know there are a few variations.
4. Should i be purchasing anything else for the block, such as a block guard?
I want to make this LSVTEC swap as reliable as it can be and i want to piece everything together CORRECT so i don't regret anything later on. With just the stock LSVTEC with the things i asked about, what should i safely red line at? Thanks for any info you guys can provide me with!
Old Aug 22, 2004 | 11:55 AM
m00tjam's Avatar
Default Re: LSVTEC Begining Questions (DAtougeSpecial)
1. i've been using a p28 and its been working fine with hondata
2. i kept the p72 head bolts its been about 20k or so miles and its running like a champ
3. OEM LS head gasket
4. rod bolts, maybe pistons (if you want the extra umph.. i guess)
good luck on the build up
Old Aug 22, 2004 | 06:32 PM
Default Re: LSVTEC Begining Questions (m00tjam)
Right on thanks ...Bump for more opinions
Old Aug 23, 2004 | 10:19 AM
Combustion Contraption's Avatar
The ARP head studs arent a must, but the rod bolts are. You might as well upgrade to some higher compression pistons, VTEC thrives on that.
Old Aug 23, 2004 | 04:31 PM
tunerz's Avatar
1.i like a jdm p30 ecu. more rpms
2.arp acura vtec b18 type r head stud kit
3.a ls/vtec easy swap kit-Golden Eagle from Robear Racing
if i can help IM me
Old Aug 23, 2004 | 10:44 PM
Default Re: LSVTEC Begining Questions (tunerz)
Hey thanks you guys! So as far as the stock lsvtec setup how much should i be revving up to safely. This is a daily driver
Old Aug 24, 2004 | 10:08 AM
Phatch99's Avatar
7.5k rpm is safe for stock lsvtec.
Old Aug 24, 2004 | 01:37 PM
tunerz's Avatar
Default Re: LSVTEC Begining Questions (Phatch99)
on 7 1/2
Old Aug 28, 2004 | 08:18 PM
Thanks! My car is a 91 so im on OBD0, what computer should i use? I have a bullfrog racing computer i can use maybe along with a v-afc. Or what computer should i get for my swap?
Nick_Cartwright
Apr 4, 2013 08:55 AM
ccbb34
Oct 29, 2012 06:52 PM
mixmastermatt
Jan 27, 2007 08:49 AM
brookliner7
Aug 30, 2005 05:27 PM
sickerhatch
Apr 15, 2005 08:57 PM
