Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   LS-Vtec Piston help (https://honda-tech.com/forums/hybrid-engine-swaps-18/ls-vtec-piston-help-3007340/)
TheHolidayCrew Dec 12, 2011 12:37 PM
LS-Vtec Piston help
So I just bought a new ls block for my ls/v build for the winter. Its a pretty complete block, only missing random hoses, ect. Now it came with some Eagle rods and CP 9.0:1 Pistons. The block is still stock, not machined or anything. The head I have is also stock.
What do you guys recommend I do to get the compression up a bit? Should I just get new slugs, or have the head machined a bit, or what?
Also, they need new rings and rod bearings as well.. Will OEM Honda fit?
Thanks in advance!
Oh, and before anyone asks goals and whatnot. I'd like to have a hi-comp ls/v, possibly on e85. And it will be a DD for the most part.
kyden Dec 13, 2011 05:07 AM
Re: LS-Vtec Piston help
get new pistons. everything else is just mickey mousing it.
