LS VTEC or GSR in 95 Hatch...
Old Nov 9, 2003 | 03:52 PM
PDXHatchback's Avatar
Default LS VTEC or GSR in 95 Hatch...
Right now I have a OBD II GSR motor in my hatch, nad was thinking about switching to an LS block...Would that be a waste of time? Which block is better for 1/4 mile. Just a thought, thanks for the input.
Joshua
Old Nov 9, 2003 | 04:08 PM
tunerz's Avatar
Default Re: LS VTEC or GSR in 95 Hatch... (PDXHatchback)
I like the LsVtec with turbo. 330 to 340 hp in a
Old Nov 9, 2003 | 05:23 PM
Quiks66's Avatar
Well if your GSR motor is trashed and ready to go out the door, I'd say go Ls/Vtec. But if you are just looking for more power, use the $$ to buy a turbo kit or something of the like. To have your GSR built with an LS block made into an Ls/Vtec, it's going to cost a bundle to do it the right way and you won't make that much more HP than your GSR. Turbo the GSR and save yourself $$ and down-time.
Old Nov 9, 2003 | 11:24 PM
If I already had the LS block, and used my GSR head, why would it be expensive?
Old Nov 10, 2003 | 08:16 AM
Full Race EG's Avatar
you will have to buy an external oil line a tap the ls block for a knock sensor. if you just bolt the head to the block it will not be very reliable and i doubt it will be much faster than what you already have. i would keep the GSR unless you plan on building the ls bottom end.
Old Nov 10, 2003 | 09:13 AM
Default Re: LS VTEC or GSR in 95 Hatch... (IntegraLStuner)
Gotcha, Thanks for the input.
Old Nov 10, 2003 | 03:38 PM
Quiks66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLStuner &raquo;</TD></TR><TR><TD CLASS="quote">you will have to buy an external oil line a tap the ls block for a knock sensor. if you just bolt the head to the block it will not be very reliable and i doubt it will be much faster than what you already have. i would keep the GSR unless you plan on building the ls bottom end.</TD></TR></TABLE>
My thoughts exactly, very well said, IntegraLStuner
Old Nov 10, 2003 | 03:53 PM
VTECVillain's Avatar
Default Re: LS VTEC or GSR in 95 Hatch... (Quiks66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiks66 &raquo;</TD></TR><TR><TD CLASS="quote">Well if your GSR motor is trashed and ready to go out the door, I'd say go Ls/Vtec. But if you are just looking for more power, use the $$ to buy a turbo kit or something of the like. To have your GSR built with an LS block made into an Ls/Vtec, it's going to cost a bundle to do it the right way and you won't make that much more HP than your GSR. Turbo the GSR and save yourself $$ and down-time.</TD></TR></TABLE>
I would have to agree here. Unless the GSR motor that you currently have is worked, I would stick with it. Put some $ in some CTR/ITR cams, maybe a Skunk2 manifold, VAFC, nice header and exhaust, basically some good bolt-ons and you'll be happy. If you have the $ to go with a mild FI setup, a turbo or JRSC would really put a on your face. I know a lot of the turbo guys are gonna jump on me for that one, but let's not hijack this thread and turn it into a turbo vs. sc debate
Old Nov 10, 2003 | 08:37 PM
stockLS's Avatar
Default Re: LS VTEC or GSR in 95 Hatch... (VTECVillain)
i looked into doing the ls-vtec on my 98 ls teg and i realized after reading that it is much to expensive ( done right that is) for the numbers that you will get! what are your goals and i would go turbo... but if money isnt an issue ls-vtec is fun to drive! ... just my 2 cents
Old Nov 10, 2003 | 10:01 PM
Quiks66's Avatar
Default Re: LS VTEC or GSR in 95 Hatch... (stockLS)
The main reason why I chose to turn my LS motor into Ls/Vtec was because it already had just over 100k miles, was losing compression, and I had the $$ to do it right. Otherwise I would have just done more bolt-ons or turbo'd (trying not to get off-topic)
duck22krazy
Nov 3, 2008 10:36 AM
LiL PaKi
28
Apr 29, 2007 02:30 PM
94si94cx
Jan 24, 2003 06:50 AM
integra81
Nov 23, 2001 09:07 AM
integra81
Nov 22, 2001 04:11 PM
