LS/VTEC dyno discussion...
With 229 peak hp this dyno caught my eye. I found this on importreview. http://www.importreview.com/d_1.8.html Does anyone know what head was used? Or anymore information about this build up. TIA!
[Modified by w00t!, 1:29 AM 2/27/2003]
please tell me why the second chart is better. that motor made less hp and less torque. i also think 143ft lbs is pretty good for an ls vtec.
2nd setup included:
Civic Type-R pistons, stock rods
B16A head, slight port/polish from Portflow
Type-R intake manifold
Iceman Race intake
Civic Type-R intake cam.
Integra Type-R exhaust cam.
DC Header, full exhaust.
I would go with the 2nd setup over the first....
That's just my .02 cents...
Just because they used ross pistons and eagle rods has nothing to do w/ performance it is more for a reliability factor you have to see what compression is used on this motor at almost 40 hp more i would take the 40hp rather than the second setup any day. Sorry but why would you take less power just cause it cost less you dont go fast cause it cost less.
JYou also have to take into consideration the 1st setup has a higher revlimit.... and also tuning is involved....
Don't get me wrong, the OEM stuff looks like it can produce some good numbers too...especially considering it's OEM. But I would definitely choose the 1st setup based on it's extended powerband. Remember: For N/A Honda applications, rpms are your friend!
Edit: BTW do you like the exhaust?
Glad I could help, err, reply completely off topic...
[Modified by Ehron, 4:55 PM 2/27/2003]
blackhatchb20
18
Nov 8, 2004 05:47 PM
