ls vtec build
ok this is my first attemt to build a reliable ls vtec....
parts: B18B1 bottom block gsr crank gsr pistons arp rod bolts b16a head ls vtec convertion kit that is the setup i would like to run but my queston is "can the gsr crank work in the ls block? and if so do i use the gsr rods or do i use the ls rods. and im not to sure if i should torque the specs to a gsr or the ls specs? (wit the arp rod bolts) |
