LS engine Swap..Need Help
Old Oct 30, 2007 | 08:22 AM
Lee_eg6si's Avatar
Default LS engine Swap..Need Help
Hi guys, I have a 94 civic si and I'm swapping in a 2000 LS motor. What I have for wiring is a 95 LS engine harness and my own 94 civic si engine harness, P75 ECU OBD1 and P75 OBD2 and P28 OBD1.. what do I need to make my engine work?? Please help ...thanks...
Modified by Lee_eg6si at 9:50 AM 10/30/2007
Old Oct 30, 2007 | 09:42 AM
racebucket_eg's Avatar
Default Re: LS engine Swap..Need Help (Lee_eg6si)
I would just use your stock civic engine harness + the obd1 P75 ecu. Should be a very straight forward swap. I know you will also need an obd1 distributor since the motor is obd2 and possibly obd1 injectors. I'll try to get a definite answer on the injectors and post up later.
Old Oct 30, 2007 | 04:24 PM
Default Re: LS engine Swap..Need Help (racebucket_eg)
You will have to use obd1 injectors. The injectors you have in your d16z6 will work fine in the LS, assuming that you still have them.
jdm_vizionz
Mar 2, 2009 09:30 AM
fcfromhell420
Jun 23, 2007 04:31 PM
Marco93EJ
Feb 17, 2007 07:09 PM
ucc crx
15
Dec 17, 2005 05:04 PM
MrEg
Nov 14, 2003 06:55 PM
