K24a wiring help!!
Old Jul 28, 2017 | 11:51 PM
Adeeb1395's Avatar
Icon4 K24a wiring help!!
I recently bought a K24a from a 2004 Honda odyssey which came with cvt tranny. Doing this swap in my DA5 integra. The engine came with uncut harness. I tried downloading the pinout from net but all the pinout seems from the tsx. I was all happy until i checked the engine harness to match with the pin-out! :-( it doesn't match at all !
The ecu part number is 37820-RFE-915
I need only the two dash/body wiring jack's pinout as the engine wiring is uncut.
And my question is are the all k24's body/under dash wiring jack pinout of the ecu same??
Thanks in advance :-)
Old Jul 31, 2017 | 06:18 PM
h23aAccord's Avatar
Default Re: K24a wiring help!!
no its not the same your best bet is to go to your local junkyard and look for the full dash harness out of a rsx preferably non automatic and take the ecu and full dash/engine harness out and make sure you take the whole ignation cause the ecu needs to read the chip in the key and bcm as well
Adeeb1395
K Series
May 7, 2019 11:29 AM
chrysanderson
Mar 24, 2011 05:42 PM
therotaryrocket
Jul 12, 2009 09:54 AM
SETI20
Oct 10, 2007 02:56 PM
