K20A2 in a EG?
Is anyone working on this mount kit? I was going to build an all motor b18c hatch for a second car but, I think the K20A2 would be a better choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by absolut b18 »</TD></TR><TR><TD CLASS="quote">how would that work? the engine spins the other way doesnt it?</TD></TR></TABLE>
I've seen pics of a EK with a K20A so I don't think that will be a problem.
if you mount it like in ths 7th gens it will work just like stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
if you mount it like in ths 7th gens it will work just like stock.</TD></TR></TABLE>
yep
just don't be stupid and try to mount it like the 5th & 6th gen civics.
yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv »</TD></TR><TR><TD CLASS="quote">
yep
just don't be stupid and try to mount it like the 5th & 6th gen civics.</TD></TR></TABLE>You mean the exhaust isn't meant to come out through the front bumper?!? Damn, that's why it hasn't been working...
yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondata »</TD></TR><TR><TD CLASS="quote">
From highest power figure to lowest power figure:
- Toda cams and ported big valve head
- ITR cams and Big valve head
- Toda cams and stock head
Car tested :RSX-S with stock bottom end. PRC intake. Comptech headers and titanium exhaust.
Conclusions from these results:
- With Toda cams the big valve head is worth about 5-10 HP from 6000 rpm up.
- With ITR cams + big valve head the power curve is only marginally better than Toda cams with a stock head.
- The ported big valve head needs bigger cams than ITR cams to work well.
No comparison can be made between ITR cams and Toda cams in a stock head. This was not tested here.
Tuning here is essential. Read very essential. The car was tested first with ITR cams and the big valve head and custom tuned to make the middle run (pink - purple). Toda cams were then swapped in. The first run with no ECU reprogramming resulted in virtually no hp change (less than 1 hp). Two hours of tuning gradually raised the power 6-10 hp. The K series engines are most sensitive to cam timing. Ignition timing was the next biggest difference followed by fuel
At the upper ends of engine of performance gains are on a diminishing return. Higher compression pistons might yield a better return than the big valve head at this point. The head is now well set up for big camshafts, which will folllow.
http://www.hondata.com/dynok20a2bigvalvehead.html</TD></TR></TABLE>
That's why! That's with a stock bottom end. That should run low 12's in a EG. What if it had 12.5 CR??
