Injector problem/distributor problem
Old Jan 29, 2005 | 04:17 PM
Jmunk's Avatar
Default Injector problem/distributor problem
I have a 94 Accord EX and put in a 2000 F20b. Which injectors do i use ? Are the F20b low impednece or saturated ? Do i need a resistor box or not ? The ones from the F20b are longer than the ones in my old motor and the fuel rails are different. Also I need a new distributor, which one do i get ?Will a H22 one work ? Also will the 94 EX ECU run the motor okay ? If not which one should i get.
Old Jan 31, 2005 | 04:59 AM
Jmunk's Avatar
Bump
andyxle
Dec 18, 2009 04:59 AM
Turbocivic94
Sep 25, 2008 11:13 AM
squarepusher
May 6, 2007 07:30 PM
mini-v-si
Mar 17, 2004 06:29 AM
