How much HP from a B20VTEC ?
Old Aug 2, 2001 | 10:38 AM
hydroflip's Avatar
Default How much HP from a B20VTEC ?
if i would use a gsr head and b20 block just bolting it up how much hp would it yield?
if i built the b20 block how much would it yield then? using 11.0 compression pistons and stock bore?
Old Aug 2, 2001 | 11:44 AM
B18CXr's Avatar
Default Re: How much HP from a B20VTEC ? (hydroflip)
165-175 hp
130+ lbs.
Old Aug 2, 2001 | 01:12 PM
stizzit's Avatar
id say with the head and block you MIGHT see 180 or 190 to the wheels absolutly tuned. Also How do you plan on using 11-1 comp. pistons with stock bore... impossible you're going to have to bore atleast "0.020 over unless you want a shitty motor. With 11-1 expect maybe 210whp about it all depends on what cams, header, head work, bottom end (rods) intake mani - throttle body - fuel system etc etc etc. If you saw the one posted the other day it was fully built putting out about 210whp at i think 155ft-lbs but it has the potential to make 235hp+
lukenordman
21
Mar 18, 2014 08:51 AM
clewis152
45
Aug 13, 2012 05:57 AM
seanmycheal
Dec 20, 2009 07:57 PM
EVO3TURBOSIR
Oct 9, 2004 06:30 PM
93Hatchbackcivic
Aug 10, 2004 01:30 PM
