how to do timing on b16?
Old Mar 7, 2003 | 12:50 PM
type Gendy's Avatar
Default how to do timing on b16?
I was reading the manual on hybrid.honda-perf, but i dont see the red mark that they show, is this something that shows up with the timing light?? Or is there a red mark on the motor that i cant find??? b16a crx
Old Mar 7, 2003 | 12:56 PM
irev210's Avatar
Default Re: how to do timing on b16? (sick hatchem)
okay, its really easy, there are 4 marks
If you look at the plastic cover on your lower timing belt cover, you will see a line.
Since you have such an old motor, the color used to dipict the middle 15 degrees of advance has probably faded.
its important to make sure your car is at PROPER idle IE 750-800ish.
If your car cant idle for crap, you cant adjust your timing, bust out the helms and correctly set your idle.
After that, make sure you have the timing light hooked up to the #1 sparkplug wire, after that shine it down following the line that is on the lower timing belt cover, make sure that your line of sight follows that line on the timing belt lower cover, this will give you more accurate results. Now, look with the timing light flashing, where the line is, you will see 3 marks in the crank pulley. The one that is the factory setting is the one in the middle. Now, loosen the bolts on your distributor if the middle dash on the crank pulley does not match up with the plastic line on the timing belt cover. Adjust the distributor by advancing or retarding it till the lines match up.
[Modified by irev210, 9:57 PM 3/7/2003]
Old Mar 7, 2003 | 02:18 PM
Lord Helmet's Avatar
first you need to clean the timing marks on the pulley and paint the marks that way when you use the timing gun it will show up. that's pretty common sense though(no flaming intended) also I highly recomend the helms manual that is the "holy bible" for all serious tuners.
Old Mar 7, 2003 | 02:26 PM
irev210's Avatar
Default Re: how to do timing on b16? (sleeperciv)
hrm, no u dont thats honestly a waste of time
Your able to see timing marks just fine with no paint on them.
Old Mar 7, 2003 | 02:31 PM
Default Re: how to do timing on b16? (irev210)
I'm just beening **** about it. they guy seems to been a rookie with the way he says it. but yeah you don't really need to paint it but it does help the first timers. also it's harder to see the marks if you have a older engine because the factory paint marks do wear down.
[Modified by sleeperciv, 3:33 PM 3/7/2003]
Fresh'86
Oct 1, 2008 04:46 AM
Dan in Japan
May 20, 2008 06:33 PM
rubbersiidedown
Oct 10, 2004 05:32 PM
slowd16z6
Mar 13, 2004 02:20 PM
durangedesign.com
Jun 17, 2003 09:10 PM
