How do I remove a pin on the ecu???????
I am trying to move a wire on the ecu and I cant figure out how to actualy pull the wire out with the clip on the plug that goes into the ecu.....after I do that I dont understand how I am going to put it into the other slot on the plug tht goes into the cu.....please help a brotha out
[Modified by On Point EK, 10:11 AM 1/9/2002]
check out http://www.geocities.com/tjsite/b16ainstall.html it should have what your looking for
just stick a small tiped flathead screw driver below (if on the bootm side of the wiring harness) and oppisite for top and then just pry it out very gentally
on the obd2 clips, you need to pull up the white tap on top of the ecu plug. then you can take a paper clip or whatever and pop out the pin.
with a small pocket screw driver. pry it up on both sides. so it comes up about 3mm. this will unlock the pins. then you can pop the clip and pull the pin out.
make sure you open the plug holder thingys that make sure the wires stay in place.
BTW it took me about 60 minutes to figure it out, now I can do it in about .6 seconds
FourthGenHatch
21
Apr 17, 2003 04:35 PM
Loaded Butane
Feb 23, 2002 05:08 PM
