Hooking up vtec this sat. one quick question
Old Aug 30, 2006 | 05:20 PM
phanatic's Avatar
Default Hooking up vtec this sat. one quick question
I have a 95 gsr motor in 93 hatch and i have to get this check engine light off and the vtec hooked up. I glanced over the how to's but i had one question. Some people i know are saying i may have to splice some wires. If i'm using a gsr wiring harness shouldnt the only thing i have to do i run the wires on the strut tower plug through the connectors and through the firewall. The original engine harness is missing the vtec wires so i thought all i had to do was put wires were there werent any.
Old Aug 31, 2006 | 10:31 AM
wakeboard_dude5's Avatar
you are correct! Just make sure you have each wire going to the right spot an you're set
Old Aug 31, 2006 | 03:36 PM
phanatic's Avatar
Default Re: (wakeboard_dude5)
thanks a lot. i'll get er done this weekend
Old Sep 6, 2006 | 06:52 PM
allstarimports1's Avatar
Default Re: (phanatic)
yea your on the right track... i had the same issue fora bit but it gets sorted out quick.. just be sure to do it as nicely as possible.. if you could re-pin the harness it would be great.. just for the sake of a clean job...
saintbhts
Aug 2, 2014 10:08 AM
leftcoast
Aug 9, 2007 08:51 PM
spoonInspired
Jul 28, 2005 09:46 PM
ahc'monracing
Jun 8, 2004 06:06 PM
